Parse duration string: as_timedelta
The as_timedelta template function parses an ISO 8601 duration string and returns a Python timedelta object. Give it a string like “PT1H30M” (1 hour and 30 minutes) or “P2DT6H” (2 days and 6 hours), and it returns a timedelta you can use in time calculations.
Some integrationsIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] and external services provide durations in ISO 8601 format. To use these values in calculations, such as adding a duration to the current time or comparing how long something will take, you need to convert them into timedelta objects first. as_timedelta does this for you. If you need to create a timedelta from numeric values (days, hours, minutes) rather than parsing a string, use timedelta instead.
Usage
{{ as_timedelta("PT1H30M") }}
1:30:00
Function signature
as_timedelta(
value: str,
) -> timedelta | None
Function parameters
ISO 8601 duration format
The ISO 8601 duration format uses P as a prefix, followed by date components and T to separate time components:
P1D- 1 day -
PT1H- 1 hour -
PT30M- 30 minutes -
PT45S- 45 seconds -
P2DT6H30M- 2 days, 6 hours, 30 minutes
{{ as_timedelta("P2DT6H30M") }}
2 days, 6:30:00
Good to know
- Returns
Nonewhen the string cannot be parsed, so guard against missing data before arithmetic. - Only the ISO 8601 duration format is accepted. A plain string like
"1h30m"will not work. For numeric inputs, usetimedelta. - Year and month components (
Y,MbeforeT) are not supported because their length in seconds is not fixed.
Try it yourself
More examples
Add a duration to the current time
Calculate when an event will end by adding a duration from a sensor to now.
{{ now() + as_timedelta("PT2H30M") }}
2024-03-15 17:00:00.123456+01:00
Get total seconds from a duration
Convert an ISO 8601 duration string to a total number of seconds for use in numeric comparisons.
{{ as_timedelta("PT1H30M").total_seconds() | int }}
5400
Check if a remaining duration is short
Determine whether a timer or countdown is about to finish by comparing the duration to a threshold.
as_timedelta(states("sensor.washer_remaining"))
< as_timedelta("PT10M")
true
Still stuck?
Related template functions
Create a time duration: timedelta - Creates a timedelta object from numeric time components.
Current local date and time: now - Returns the current date and time in your local time zone.
Convert to datetime: as_datetime - Converts a string or timestamp to a datetime object.
Convert to UNIX timestamp: as_timestamp - Converts a datetime object or string to a UNIX timestamp.
