Convert to datetime: as_datetime
The as_datetime template function converts a date/time string or a UNIX timestamp into a datetimeA value representing a specific moment in time, including the date, time, and time zone. For example, 2026-04-05 14:30:00+00:00. Used for timestamps, scheduling, and time-based calculations. object. Give it an ISO 8601 formatted string like “2024-03-15T14:30:00” or a numeric timestamp, and it returns a proper datetime you can work with in your templates.
Many sensorsSensors return information about a thing, for instance the level of water in a tank. [Learn more] and integrationsIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provide dates and times as plain text strings or UNIX timestamps. To compare those values with now, calculate time differences, or format them for display, you first need to turn them into datetime objects. as_datetime handles this conversion for you. It accepts ISO 8601 formatted strings (the most common format in Home Assistant) as well as numeric UNIX timestamps.
Usage
{{ as_datetime("2024-03-15T14:30:00+01:00") }}
2024-03-15 14:30:00+01:00
Function signature
as_datetime(
value: str | int | float,
default: Any = None,
) -> datetime | Any
Function parameters
Converting from a UNIX timestamp
You can also convert a numeric UNIX timestamp (seconds since January 1, 1970) into a datetime object.
{{ as_datetime(1710510600) }}
2024-03-15 14:30:00+00:00
Using a default value
If the input string might be invalid, provide a default value to avoid errors.
{{ as_datetime("not a date", default="unknown") }}
unknown
Good to know
- Strings without a time zone are treated as local time; strings with an offset or
Zsuffix keep the original zone. - UNIX timestamps are interpreted in UTC, so chain with
as_localif you need local time. - Without a default, an unparseable input raises an error.
Try it yourself
More examples
Convert a sensor value to a datetime
Many sensors store dates as strings. Convert them to datetime objects to perform comparisons or calculations.
{{ as_datetime(states("sensor.next_appointment")) }}
Calculate time until a future event
Convert a date string from a sensor and calculate how many hours remain until that event.
{% set event = as_datetime(states("sensor.next_appointment")) %}
{{ ((event - now()).total_seconds() / 3600) | round(1) }}
3.5
Chain with as_local
Convert a UTC datetime string to your local time zone by chaining as_datetime with as_local.
{{ as_datetime("2024-03-15T13:30:00+00:00") | as_local }}
Still stuck?
Related template functions
Convert to UNIX timestamp: as_timestamp - Converts a datetime object or string to a UNIX timestamp.
Convert to local time zone: as_local - Converts a datetime object to your local time zone.
Parse duration string: as_timedelta - Parses an ISO 8601 duration string into a timedelta object.
Parse a time string: strptime - Parses a time string with a specified format into a datetime object.
Current local date and time: now - Returns the current date and time in your local time zone.
