Get devices in an area: area_devices
The area_devices template function returns a list of device IDs that belong to a given areaAn area in Home Assistant is a logical grouping of devices and entities that are meant to match areas (or rooms) in the physical world: your home. For example, the living room area groups devices and entities in your living room. [Learn more]. You can specify the area by its name or by its internal ID. While area_entities gives you individual entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] IDs, area_devices gives you the devicesA device is a model representing a physical or logical unit that contains entities. themselves.
This is useful when you need to work at the device level rather than the entity level. For example, you might want to count how many physical devices are in a room, check if a specific device is assigned to an area, or loop through all devices to find their attributes. Each device can have multiple entities, so the device list is typically shorter than the entity list for the same area.
Usage
{{ area_devices("Living Room") }}
"a1b2c3d4e5f6a1b2c3d4e5f6",
"f6e5d4c3b2a1f6e5d4c3b2a1",
Function signature
area_devices(
area_name_or_id: str,
) -> list[str]
Function parameters
The name or ID of the area. You can find area IDs in Settings > Areas, labels & zones.
Good to know
- Returns an empty list when the area has no devices or when the name does not match. It does not raise an error.
- A device can only belong to one area. Entities assigned directly to an area but not through a device are not included here.
- The list contains device IDs, not entity IDs. Use
device_entitiesto get entities from each device.
Try it yourself
More examples
Count how many devices are in a room
Find out how many physical devices are assigned to an area.
{{ area_devices("Kitchen") | count }}
5
Get the name of each device in an area
Loop through all devices in an area and display their names using device_name.
{% for device_id in area_devices("Living Room") %}
{{ device_name(device_id) }}
{% endfor %}
Check if any device in an area has a firmware update
Combine area_devices with entity lookups to see if any device in a room has a pending update.
area_devices("Office")
| map("device_entities")
| sum(start=[])
| select("match", "update.")
| select("is_state", "on")
| list
| count > 0
true
Still stuck?
Related template functions
Get entities in an area: area_entities - Returns a list of entity IDs associated with a given area.
Get all areas: areas - Returns a list of all area IDs in your Home Assistant instance.
Get area ID: area_id - Returns the area ID for a given area name, entity ID, or device ID.
Get area name: area_name - Returns the friendly name of an area from its ID, entity ID, or device ID.
