No page for this action
There is no documentation page for the action you were looking for. This can have a few reasons:
  • The action comes from a custom integration. Custom integrations and tools that add their own actions document those actions themselves. Check the documentation of the custom integration you installed.
  • The action is named after something you created. Some actions are named after your own scripts or commands, like script.good_morning or shell_command.clean_up. These don’t have their own page. See the documentation of the integration instead, like scripts, shell commands, or RESTful commands.
  • The action was removed or deprecated. Actions that are no longer supported are removed from the documentation. If an automation or script still uses it, Home Assistant usually tells you what to use instead under Settings > System > Repairs.
To find an action on your own system, go to Settings > Tools > Actions and search for it. Every available action is listed there, along with any description and options it provides.
You can also browse all documented actions, or search the documentation using the search at the top of this page.
