Xthings Cloud
The Xthings Cloud integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control and monitor your Xthings smart home devices through the Xthings Cloud service. This integration currently supports the U-tec Bright A19 Color smart light bulb.
Use case: Control your Xthings smart lights from a single Home Assistant dashboard with real-time status updates via WebSocket push.
Supported devices
The following device types are supported:
- U-tec Bright A19 Color light bulb (Xthings Cloud): on/off, brightness, HS color, color temperature
Before setting up the integration, make sure you have:
- A Xthings Cloud account. You can create one in the Xthings mobile app.
- At least one light device added and online in the Xthings app.
- If your account has two-factor authentication (2FA) enabled, have access to your registered email or phone to receive verification codes.
To add the Xthings Cloud hub to your Home Assistant instance, use this My button:
From the list, select Xthings Cloud.
Supported functionality
The Xthings Cloud integration provides the following entities.
Lights
Smart light
- Description: On/off, brightness (0–100%), HS color, and color temperature (2000–6500K) control.
- Remarks: Devices with brightness in their status are automatically registered as light entities.
Data updates
The Xthings Cloud integration uses a combination of push and pollingData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] for data updates:
- WebSocket push (primary): The integration maintains a persistent WebSocket connection to the Xthings Cloud. Device status changes and online/offline events are pushed in real-time, typically within 1–2 seconds.
- Polling (fallback): As a safety net, the integration polls the cloud API every 30 minutes to ensure data consistency in case of missed WebSocket messages.
Known limitations
- The integration communicates with devices through the Xthings Cloud service. If the cloud service is unavailable, devices cannot be controlled.
Unable to connect during setup
Symptom: “Unable to connect to Xthings Cloud”
The setup form shows the error “Unable to connect to Xthings Cloud”.
Resolution
- Check your internet connection.
- Verify that
api.cloud.xthings.comis reachable from your network. - If you are behind a corporate firewall or proxy, ensure HTTPS traffic to
api.cloud.xthings.comis allowed.
Incorrect password
Symptom: “Incorrect password”
The setup form shows the error “Incorrect password”.
Resolution
- Double-check your password in the Xthings mobile app.
- If you have forgotten your password, use the “Forgot Password” feature in the app to reset it.
Devices not showing up
After successful setup, some or all devices are missing.
Resolution
- Make sure the devices are added and online in the Xthings mobile app.
- Go to Settings > Devices & services > Xthings Cloud > ⋮ > Reload to refresh.
- Check the Home Assistant logs for any error messages from
xthings_cloud.
menu. Then, select Delete.
