Specialized Turbo
The Specialized Turbo integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] connects Home Assistant to Specialized Turbo e-bikes over Bluetooth Low Energy. The integration reads battery, motor, ride, and system telemetry from the bike.
You can use this data to track battery health, record ride information, or create battery charge notifications.
Supported devices
The integration supports Specialized Turbo bikes with these Bluetooth systems:
  • TCU1
  • TCX1
  • TCX2
  • TCX3
  • TCX4
These systems are available in models from the Turbo Vado, Levo, Creo, Como, and Tero families. The integration supports legacy TURBOHMI advertisements, modern advertisements, and bikes that advertise only a WSBC... name.
Unsupported devices
The integration does not support these devices:
  • Specialized bikes without Bluetooth
  • Non-Turbo Specialized bikes
  • E-bikes from other manufacturers
  1. Turn on the bike.
  2. Make sure that Home Assistant has access to a Bluetooth adapter.
  3. If you use an ESPHome Bluetooth proxy, enable active connections on the proxy.
  4. Disconnect the Specialized app and other Bluetooth clients from the bike.
An encrypted bike also requires one of these items:
  • A Specialized account that contains the bike
  • The 64-character wrapped key for the bike
Home Assistant uses your account password only during key retrieval. Home Assistant stores the wrapped bike key, but it does not store the password or account token.
To add the Specialized Turbo device to your Home Assistant instance, use this My button:
  • From the list, select Specialized Turbo.
The bike is usually discovered automatically. If it is not listed, add the integration from Settings > Devices & services.
Encryption key source
For an encrypted bike, select your Specialized account or manual wrapped-key entry.
Specialized account email
The email address for the Specialized account that contains the bike.
Specialized account password
The integration sends this password to Specialized during key retrieval. Home Assistant does not store it.
Wrapped key
The 64-character wrapped key for the bike. Use this option if you do not want to use a Specialized account.
The Bluetooth backend manages bike pairing. The integration does not ask for or store a pairing PIN.
Some bikes require confirmation in the operating system. If the Bluetooth backend cannot show this request, pair the bike in the operating system first.
Reconfigure an encryption key
You can replace the stored key for an encrypted bike. Use this function after a display replacement or an invalid-key error.
  1. Go to Settings > Devices & services.
  2. Select the Specialized Turbo integration.
  3. Open the three-dot menu for the bike.
  4. Select Reconfigure.
  5. Select a Specialized account or manual wrapped-key entry.
Home Assistant starts reauthentication when a stored key is missing, invalid, or stale.
Supported functionality
Entities
The Specialized Turbo integration provides 26 sensor entities.
Sensors
  • Battery
    • Description: Current battery charge in percent
  • Battery capacity
    • Description: Total battery capacity in watt-hours
  • Battery remaining
    • Description: Remaining battery energy in watt-hours
  • Battery health
    • Description: Battery health in percent
    • Category: Diagnostic
  • Battery temperature
    • Description: Battery temperature
  • Charge cycles
    • Description: Total number of battery charge cycles
  • Battery voltage
    • Description: Current battery voltage
  • Battery current
    • Description: Current battery input or output
  • Speed
    • Description: Current bike speed
  • Rider power
    • Description: Power from the rider in watts
  • Motor power
    • Description: Power from the motor in watts
  • Cadence
    • Description: Pedaling cadence in revolutions per minute
  • Odometer
    • Description: Total bike distance
  • Motor temperature
    • Description: Motor temperature
  • Assist level
    • Description: Current assist mode: Off, Eco, Trail, or Turbo
  • ECO assist
    • Description: Configured assistance for Eco mode
    • Remarks: Disabled by default
  • Trail assist
    • Description: Configured assistance for Trail mode
  • Turbo assist
    • Description: Configured assistance for Turbo mode
  • Range (long)
    • Description: Estimated range for the long-range calculation
  • Range (short)
    • Description: Estimated range for the short-range calculation
  • Altitude
    • Description: Current altitude
  • Altitude gain
    • Description: Total altitude gain
  • Gradient
    • Description: Current gradient in percent
  • System temperature
    • Description: Temperature reported by the bike system
  • Consumption
    • Description: Energy consumption in watt-hours per kilometer
  • Calories
    • Description: Total ride energy in kilocalories
Automation examples
Notify when the battery is fully charged
- alias: "Bike battery full"
  triggers:
    - trigger: numeric_state
      entity_id: sensor.specialized_turbo_battery
      above: 99
  actions:
    - action: notify.send_message
        entity_id: notify.my_device
        message: "Your bike is fully charged."
Warn when battery health decreases
- alias: "Bike battery health warning"
  triggers:
      entity_id: sensor.specialized_turbo_battery_health
      below: 80
  actions:
        message: >
          Bike battery health is at
          {{ states(
            'sensor.specialized_turbo_battery_health'
          Consider scheduling a service.
Data updates
The integration keeps an active Bluetooth connection while the bike is awake and in range. The bike sends telemetry changes through Bluetooth notifications.
The integration also requests telemetry periodically. This request supplies values that the bike does not send through notifications.
If the connection stops, the entities become unavailable. The integration reconnects after it receives another advertisement from the bike.
Known limitations
  • Bluetooth range: The bike must be near a Bluetooth adapter. The typical range is 5 to 10 meters.
  • One connection at a time: Disconnect the Specialized app before Home Assistant connects.
  • Read-only access: The integration cannot change assistance, tuning, or bike configuration.
  • Sleep mode: The bike stops Bluetooth communication when it sleeps.
  • Encrypted setup: Account key retrieval requires internet access during setup or reauthentication.
  • Bluetooth proxies: Some ESPHome proxies cannot complete operating-system pairing requests.
Move from the HACS integration
The Core integration uses the same domain and entity unique IDs as the HACS integration.
  1. Update the HACS integration to version 0.6.0 or later.
  2. Restart Home Assistant.
  3. Remove the Specialized Turbo custom integration files from HACS.
  4. Do not delete the Specialized Turbo configuration entry.
  5. Restart Home Assistant with a version that includes the Core integration.
Home Assistant keeps the configuration entry, the encrypted bike key, and the entity registry entries.
Privacy
The integration can contact Specialized during encrypted bike setup. This request retrieves the wrapped key for the selected bike.
Home Assistant does not store the Specialized account password or account token.
The bike is not discovered
Symptom: The bike is not listed during setup
The bike can be asleep, out of range, or unavailable to the Bluetooth adapter.
Resolution
  2. Move the bike near the Bluetooth adapter.
  3. Make sure that the Bluetooth integration is available.
  4. If you use an ESPHome proxy, make sure that active connections are enabled.
Older bikes can advertise only a WSBC... name. The integration supports this name and selects the protocol after connection.
The bike does not connect
Symptom: Setup reports that the bike connection cannot complete
Another Bluetooth client can hold the connection. The Bluetooth backend can also require operating-system pairing.
Resolution
  1. Disconnect the Specialized app from the bike.
  2. Remove an old bike pairing from the operating system.
  3. Pair the bike in the operating system.
  4. Start the Home Assistant setup again.
If you use an ESPHome proxy, complete the first pairing through a local Bluetooth adapter when possible.
Sensor entities are unavailable
Symptom: All bike sensor entities show Unavailable
The bike is asleep, out of range, or disconnected from Home Assistant.
Resolution
  1. Wake the bike.
  3. Disconnect other Bluetooth clients.
  4. Reload the integration from Settings > Devices & services.
The encryption key is unavailable
Symptom: Setup cannot retrieve or use the bike key
The account credentials can be incorrect. The Specialized service can also be unavailable.
Resolution
  1. Make sure that Home Assistant has internet access.
  2. Make sure that the bike is present in the Specialized account.
  3. Enter the account credentials again.
  4. If account retrieval fails, enter the wrapped key manually.
More than one WSBC... device is listed
Some bikes expose more than one Bluetooth endpoint. Select the endpoint that is present, has a current signal, and accepts pairing.
An endpoint with a signal strength of -127 can be stale or unavailable.
