Persang Infrared
The Persang Infrared integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you control a Persang Bluetooth speaker using any infrared transmitter previously configured in Home Assistant.
Because the integration communicates over infrared, it operates in a one-way, fire-and-forget fashion: commands are sent to the speaker but there is no feedback channel to confirm the current state. The integration therefore uses assumed states, and restores the last state it sent after a restart.
This integration requires an infrared remote adapter (proxy) that is already set up in Home Assistant and provides an infrared entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more]. To find integrations that provide infrared entities, browse the Infrared category.
For example, you can use an ESPHome device with an IR LED pointed at your speaker.
To add the Persang Infrared device to your Home Assistant instance, use this My button:
From the list, select Persang Infrared.
Supported devices
The IR commands were captured from the remote shipped with a Persang Octane 9 speaker. Persang sells the same remote as a spare part for several of its speakers, so other Persang models are likely to respond to the same commands, but only the Octane 9 has been verified.
If your speaker does not respond, or if you want another Persang remote supported, please open an issue on the infrared-protocols repository with captured IR signals from your remote.
Supported functionality
The Persang Infrared integration provides the following entities.
Media player
Persang speaker
- Description: Represents the speaker and allows you to control it over IR.
- Supported features: Turn on, turn off, volume up, volume down, mute, play, pause, next track, and previous track.
Buttons
Button entities are provided for the remaining remote buttons, which the media player entity does not expose:
- Mode: Cycles through the speaker’s playback modes.
- Equalizer: Cycles through the speaker’s equalizer presets.
- Scan: Starts scanning the current source.
- Repeat: Cycles through the repeat modes.
- Number 0 to Number 9: Sends the corresponding numeric key, which the speaker uses to select a track.
Known limitations
- The integration uses assumed state, meaning Home Assistant cannot read the actual state of the speaker (for example, whether it is on or off, or what the current volume is).
- Presses on the physical remote are not tracked. The integration only sends commands through an infrared transmitter, so using the remote directly leaves the entities showing whatever state Home Assistant last set.
- Turning on and turning off the speaker both send the same IR power toggle command, as is standard with infrared remotes. The same applies to play and pause, and to muting and unmuting. The command is always sent, so if the speaker and Home Assistant disagree, sending the opposite command brings them back in sync.
- Volume control is step-based only; there is no way to set an absolute volume level.
- Mute is not restored after a restart.
- Source selection is not exposed, because the remote has no dedicated source buttons.
- The mode, equalizer, and repeat buttons cycle through the available settings, so Home Assistant cannot select a specific one or tell which one is active.
menu. Then, select Delete.
