Mitsubishi Comfort
The Mitsubishi Comfort integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] connects Mitsubishi Electric ductless minisplit heat pump and air conditioning systems to Home Assistant. It communicates directly with each indoor unit over your local network for low-latency control, using the Kumo Cloud account only for initial device discovery and credential retrieval.
This integration supports indoor units (full climate control) and Kumo Station outdoor units (temperature monitoring only).
Supported devices
  • Indoor unit (ductless, ducted)
    • Controls: mode, temperature, fan speed, vane direction
    • Sensors: temperature, humidity, filter status, Wi-Fi signal
  • Kumo Station (outdoor unit, read-only)
    • Sensors: outdoor temperature, Wi-Fi signal
  • A Kumo Cloud account with your Mitsubishi devices registered
  • Devices must be connected to your local network via their Wi-Fi adapters
  • During setup you will be asked to enter the username and password for your Kumo Cloud account. The integration uses these credentials to discover your devices and retrieve the local API passwords needed for direct communication.
To add the Mitsubishi Comfort hub to your Home Assistant instance, use this My button:
  • From the list, select Mitsubishi Comfort.
Username
The email address for your Kumo Cloud account.
Password
The password for your Kumo Cloud account.
Supported functionality
The Mitsubishi Comfort integration provides the following entities.
Climate
Each indoor unit is exposed as a climate entity with the following capabilities:
  • HVAC modes: Off, Cool, Heat, Dry, Fan only, Heat/Cool (auto)
    • Availability depends on the specific unit.
  • Fan modes: Super quiet, Quiet, Low, Powerful, Super powerful, Auto
    • The number of available speeds depends on the unit.
  • Swing modes: Horizontal, Mid-Horizontal, Midpoint, Mid-Vertical, Vertical, Auto, Swing
    • Availability depends on the unit.
  • Temperature: Single setpoint in Cool and Heat modes, separate high and low setpoints in Heat/Cool (auto) mode.
    • Temperature ranges vary by unit and mode.
Data updates
The Mitsubishi Comfort integration pollsData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] the status of your devices every 60 seconds. When you send a command (such as changing the mode or adjusting the temperature), Home Assistant reflects the change straight away, without waiting for the next poll.
Removing the integration stops all polling and closes connections to the devices. Your Kumo Cloud account and device settings are not affected.
