Grandstream Home
The Grandstream Home integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to integrate Grandstream devices with Home Assistant for monitoring. This integration supports door access control systems (GDS372x, GSC356X).
Supported devices
This integration supports the following Grandstream device types:
GDS/GSC series - door access control systems
Door access control devices with SIP calling capabilities.
- GDS372x series devices
- GSC356X series devices
Grandstream device connected to your local network
Device administrator credentials for the
gdshaaccount -
Device must be accessible from your Home Assistant instance
Home Assistant control must be enabled on the device (for GDS/GSC devices):
- Log in to the device web interface.
- Go to Access Control Settings > Basic Settings.
- Enable the Home Assistant option and save.
To add the Grandstream Home device to your Home Assistant instance, use this My button:
Grandstream Home can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Grandstream Home.
The HTTPS port of your device. This is pre-filled with the port from device discovery, or 443 by default.
Supported functionality
Sensors
The integration provides the following sensor entity:
GDS/GSC devices
Device status - Overall device status showing:
available- Device is idle with an available account -
busy- Device is currently on a call -
ringing- Device is ringing -
preview- Device is in call preview state -
no_available_account- No account is available on the device -
offline- Device is not reachable
Known limitations
- Only sensors are supported in the initial release.
- Device discovery requires mDNS/Zeroconf to be enabled on your network.
- Some older device firmware versions may have limited functionality.
Cannot connect to device
Connection error during setup
When you set up the integration, configuration fails with a “Cannot connect” error, or the device shows as unavailable.
To resolve this issue, try the following steps:
Verify that the device is powered on and connected to the network.
Check that the IP address is correct.
Confirm that your Home Assistant instance can reach the device:
ping <device-ip>
Sensors not updating
Sensor values are stale or not updating
- Check device is online and accessible.
- Verify device firmware is up to date.
- Check Home Assistant logs for errors:
- Go to Settings > System > Logs.
- Try reloading the integration:
- Find Grandstream Home.
- Select the three dots
menu. - Select Reload.
Authentication errors
Invalid authentication error
When you set up the integration or during normal operation, the device becomes unavailable with authentication errors.
- Verify the password is correct (default username:
gdsha). - Confirm that the account is not locked due to excessive failed login attempts.
- Reset the device password if necessary.
- Verify the Home Assistant option is enabled in the device web interface under Access Control Settings > Basic Settings.
Home Assistant control disabled
Home Assistant control is disabled error
- Enable the Home Assistant option.
- Save settings and retry the integration setup.
Security considerations
- The integration stores credentials locally in Home Assistant’s configuration storage. Make sure you protect your backups, and limit access to your Home Assistant system.
- Communication with devices uses HTTPS by default (port 443).
- Keep SSL certificate verification enabled whenever possible. If your device uses a self-signed certificate, you can disable verification, but this reduces security and should only be used if you understand the risk.
- Administrator password is required for full functionality.
- Home Assistant control must be explicitly enabled on the device.
- Devices
- Hubs
- Services
- Integration entries
- To confirm, select Delete.
