Everything Smart Home
Everything Smart Home makes presence sensors built on ESPHome, including the Everything Presence Lite, Everything Presence One, and Everything Presence Pro.
Everything Smart Home devices work locally and integrate seamlessly with the ESPHome integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] in Home Assistant. As all connectivity is done locally, status updates and device control from Home Assistant happen instantly.
Support for devices by Everything Smart Home in Home Assistant is provided by the ESPHome integration.
Everything Smart Home devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the ESPHome integration.
To add the Everything Smart Home integration to your Home Assistant instance, use this My button:
Everything Smart Home can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
  • From the list, select Everything Smart Home.
Usage information
For more documentation on how to use Everything Smart Home in Home Assistant, please refer to the ESPHome integration documentation page.
Works with Home Assistant certified devices
