Dyson Infrared
The Dyson Infrared integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you control a Dyson device using any infrared transmitter previously configured in Home Assistant.
Because the integration communicates over infrared, it operates in a one-way, fire-and-forget fashion: commands are sent to the device but there is no feedback channel to confirm the current state of the device. The integration therefore uses assumed states.
This integration requires an infrared remote adapter (proxy) that is already set up in Home Assistant and provides an infrared entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more]. To find integrations that provide infrared entities, browse the Infrared category.
For example, you can use an ESPHome device with an IR LED pointed at your Dyson device.
To add the Dyson Infrared device to your Home Assistant instance, use this My button:
  • From the list, select Dyson Infrared.
Device type
The type of Dyson device to control. Currently, only Fan is supported.
Infrared transmitter
The infrared transmitter entity to use for sending commands. This must be an entity provided by a hardware integration (such as ESPHome) that has already been set up with an IR transmitter.
Supported devices
The integration supports Dyson Fan that can be controlled via the standard Dyson infrared protocol.
