Bosch Smart Camera
The Bosch Smart Camera integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] connects your Bosch SingleKey ID account to Home Assistant. Each camera of the account is added as a camera entity that shows the latest available event image.
Supported devices
The following cameras are supported with this account:
- Eyes Outdoor camera
- 360° Indoor camera
- Eyes Outdoor camera II
- Eyes Indoor camera II
You need a Bosch SingleKey ID account that has at least one camera registered in the Bosch Smart Camera app.
To add the Bosch Smart Camera hub to your Home Assistant instance, use this My button:
From the list, select Bosch Smart Camera.
You are redirected to the Bosch login page to sign in with your SingleKey ID.
Supported functionality
The integration adds one camera entity per camera of the account. The entity shows the latest available event image, for example a motion or person event. It is not a live image. The image is cached for 60 seconds, so dashboards and automations can request it often without extra load on the Bosch cloud.
Each camera is also added as a device, together with its model and firmware version. Cameras that are added to or removed from the account are added or removed in Home Assistant automatically.
Data updates
The integration polls the Bosch cloud for the list of cameras every 5 minutes. The image of a camera is only retrieved when it is requested.
Known limitations
Event images
Live streaming is not available yet. The camera entity only shows the latest available event image. A camera without any event image has no image to show.
Cloud connection
A cloud connection is required.
The login page does not return to Home Assistant
Symptom
After signing in, you are not sent back to Home Assistant.
Resolution
- Make sure My Home Assistant is configured with your instance URL in the same browser you use to sign in.
- Start the setup again from Settings > Devices & services.
- Devices
- Hubs
- Services
- Integration entries
- To confirm, select Delete.
