AWS S3
The AWS S3 integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to use AWS S3 bucket with Home Assistant Backups.
This integration is specifically designed to work only with Amazon AWS S3 and not with third-party storage providers that claim S3 API compatibility. Third-party providers like Wasabi, DigitalOcean Spaces, Backblaze B2, Infomaniak, and others are not supported.
This integration requires an existing S3 bucket and an IAM user that has access to that bucket. For security reasons, it is strongly recommended to scope the IAM policy as narrowly as possible to only the required operations and resources.
Create a new S3 bucket
- Log in to the AWS Management Console.
- Navigate to S3 from the Services menu.
- Click Create bucket.
- Choose a unique bucket name (for example,
home-assistant-backups-123456). - Select your preferred AWS region (for example,
eu-central-1). - Adjust the settings:
- β Block all public access (enabled by default, recommended)
- β οΈ Enable Bucket Versioning (optional). This lets you recover backups after Home Assistant deletes them, but it can increase storage costs. Disable this to allow permanent deletion based on retention settings.
Make a note of the bucket name β youβll need it later.
Create an IAM user
To create a new IAM user that can access the S3 bucket:
- Go to IAM > Users in the AWS Management Console.
- Click Add users.
- Use a name like
home-assistant-backup. - Check Access key - Programmatic access only.
- Click Next: Permissions.
Now, letβs create and attach a custom IAM policy to give the user the necessary permissions to the bucket:
Click Create policy, go to the JSON tab, and paste the following (replace
YOUR_BUCKET_NAME):{ "Version": "2012-10-17", "Statement": [ { "Sid": "AllowS3BackupOperations", "Effect": "Allow", "Action": [ "s3:ListBucket", "s3:GetObject", "s3:PutObject", "s3:DeleteObject", "s3:AbortMultipartUpload" ], "Resource": [ "arn:aws:s3:::YOUR_BUCKET_NAME", "arn:aws:s3:::YOUR_BUCKET_NAME/*" ] } ] } -
Name the policy (for example,
HomeAssistantS3Policy) and create it. -
Return to the user creation wizard and attach the new policy.
Complete the user setup.
Save the Access Key ID and Secret Access Key β youβll need these when setting up the AWS S3 integration in Home Assistant.
Avoid using credentials for your AWS root account or IAM users that have more permissions than is necessary.
By limiting credentials to a specific bucket, you reduce risk and help keep your AWS account secure.
To add the AWS S3 service to your Home Assistant instance, use this My button:
If the above My button doesnβt work, you can also perform the following steps manually:
From the list, select AWS S3.
S3 bucket name to store the backups. Bucket must already exist and be writable by the provided credentials.
Endpoint URL provided to Boto3 Session. Region-specific AWS S3 endpoints are available in their documentation. Defaults to https://s3.eu-central-1.amazonaws.com/.
Optional path prefix within the S3 bucket where backups will be stored. For example, home-assistant will store backups in s3://bucket-name/home-assistant/. This is useful for organizing backups when using the same bucket for multiple purposes. Leading and trailing slashes will be automatically removed.
Setting up the AWS S3 integration in Home Assistant
- In Home Assistant, go to Settings > Devices & services.
- Select Add Integration and search for AWS S3.
- Enter the following details:
- Access Key ID and Secret Access Key from the IAM user
- Your bucket name
- The region endpoint (for example,
https://s3.eu-central-1.amazonaws.com/) - The optional prefix (path inside the bucket for organizing backups; you can leave this empty)
The integration will test the connection and confirm access to your S3 bucket.
Organizing backups with the prefix option
The optional prefix option allows you to organize your backups within a specific path inside your S3 bucket. This is useful when you want to:
- Store backups in a dedicated path (for example,
home-assistant/backups/) - Use the same S3 bucket for multiple purposes
- Manage multiple Home Assistant instances with separate backup paths
Examples
Without prefix
Backups are stored at the root of your bucket:
s3://my-bucket/
βββ backup-2025-02-01.tar
βββ backup-2025-02-01.metadata.json
βββ backup-2025-02-02.tar
βββ backup-2025-02-02.metadata.json
With prefix home-assistant
Backups are stored in a path prefix:
s3://my-bucket/home-assistant/
With nested prefix backups/home-assistant
Backups are stored in nested prefixes:
s3://my-bucket/backups/home-assistant/
The prefix is automatically normalized, so you can enter it with or without leading/trailing slashes. For example, home-assistant, /home-assistant, and home-assistant/ all work the same way.
Sensors
The integration provides the following sensor, which is updated every 6 hours:
- Total size of backups: The combined size of all Home Assistant backups stored in the configured S3 bucket for this Home Assistant installation.
Known limitations
The AWS S3 integration has the following limitations:
No support for third-party S3 API compatible providers
This integration is designed to work only with the official Amazon AWS S3 service. Despite claims of S3 API compatibility, third-party storage providers like Wasabi, DigitalOcean Spaces, Backblaze B2, Infomaniak, OVH Cloud, and others have often proven to be incompatible. Even when they appear to work initially, they cannot guarantee ongoing compatibility with this AWS S3 integration in the future.
- Devices
- Hubs
- Services
- Integration entries
- To confirm, select Delete.
