Test if true: true
The true test checks whether a value is true. It performs a strict identity check, meaning only the boolean value true passes. Values like 1, true, or non-empty strings do not match.
This is useful when you need to verify that a value is specifically the boolean true and not merely a truthy value. In Home Assistant, entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] attributes can be actual booleans, and this test lets you check for an exact true value without accidentally matching other truthy types.
Usage
As a test
{% if true is true %}
  It is true
{% endif %}
It is true
Function signature
true(
    value: Any,
) -> bool
Function parameters
The following parameters can be provided to this test.
value any Required
The value to test. Returns true only if the value is the boolean true.
Good to know
  • This is a strict identity check. Truthy values like 1, "yes", or a non-empty list do not pass. Use boolean if you want looser matching.
  • The string "true" is not the boolean true. Entity states are always strings, so comparing a state with this test always returns false.
Try it yourself
More examples
Strict boolean check
Only the boolean true passes; truthy values like 1 or true do not.
{{ true is true }}
{{ 1 is true }}
{{ "true" is true }}
true
false
false
Verify a boolean attribute
Check that an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] attribute is specifically true.
{% set locked = state_attr("lock.front_door", "is_jammed") %}
{% if locked is true %}
  Door is jammed!
{% endif %}
Door is jammed!
Still stuck?
Tip
Related template functions
