Set symmetric difference: symmetric_difference
The symmetric_difference template function returns a list of items that are in either of the two lists, but not in both. This is the set symmetric difference operation: it gives you the items that are unique to each list, excluding any items that the two lists share.
This is useful when you want to find what has changed between two collections. For example, you might compare today’s list of active devicesA device is a model representing a physical or logical unit that contains entities. with yesterday’s to see which devices were added or removed. Or you might compare the members of two groups to find which entitiesAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] are exclusive to each group. It effectively combines the results of two difference calls in both directions. Duplicates are removed from the result since it operates as a set operation.
Usage
{{ symmetric_difference([1, 2, 3, 4], [3, 4, 5, 6]) }}
[1, 2, 5, 6]
Function signature
    value: list,
    other: list,
) -> list
Function parameters
value list Required
The first list. Must be a list or collection.
other list Required
The second list. Must be a list or collection.
Good to know
  • Duplicates within either input list are collapsed: the result treats both inputs as sets.
  • The order of items in the result is not guaranteed, so do not rely on a specific ordering.
Try it yourself
More examples
Find devices exclusive to each group
Determine which entitiesAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] are in one group but not the other, and vice versa.
{% set morning = ["light.kitchen", "light.hallway", "light.bedroom"] %}
{% set evening = ["light.hallway", "light.bedroom",
                  "light.porch", "light.living_room"] %}
{{ symmetric_difference(morning, evening) }}
["light.kitchen", "light.porch", "light.living_room"]
Detect changes in a list
Compare a previous and current list to find items that were added or removed.
{% set previous = ["sensor.temp_a", "sensor.temp_b", "sensor.temp_c"] %}
{% set current = ["sensor.temp_b", "sensor.temp_c", "sensor.temp_d"] %}
{{ symmetric_difference(previous, current) }}
["sensor.temp_a", "sensor.temp_d"]
Still stuck?
Tip
Related template functions
