Test if string: string
The string test checks whether a value is a string. It returns true if the value is of string type and false for any other type, including numbers and booleans.
In Home Assistant, entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] states are always strings, but attributes can be various types including numbers, booleans, and lists. This test is useful when you need to verify that a value is a string before performing string operations like splitting, replacing, or pattern matching.
Usage
{% if "hello" is string %}
It is a string
{% endif %}
It is a string
Function signature
string(
value: Any,
) -> bool
Function parameters
The following parameters can be provided to this test.
Good to know
- A numeric-looking string such as
"42"still passes this test. The test looks at the type, not the content. - All entity states are strings in Home Assistant, so this test is most useful for attributes or values built inside a template.
Try it yourself
More examples
Distinguish strings from numbers
Check whether a value is a string or a numeric type.
{{ "hello" is string }}
{{ 42 is string }}
{{ "42" is string }}
true
false
true
Conditionally process based on type
Handle an attribute differently depending on whether it is a string or another type.
{% set val = state_attr("sensor.device", "info") %}
{% if val is string %}
Info: {{ val }}
{% else %}
Info: {{ val | tojson }}
{% endif %}
Info: Ready
Still stuck?
Related template functions
Convert to string: string - Converts a value to its string representation.
Get the type of a value: typeof - Returns the type name of a value as a string.
