Statistical mode: statistical_mode
The statistical_mode template function returns the most commonly occurring value in a collection. Give it a list of values and it returns the one that appears most often. If multiple values share the highest frequency, it returns the first one encountered.
This is useful when you want to find the most frequent reading from a set of sensorsSensors return information about a thing, for instance the level of water in a tank. [Learn more] rather than a numeric average. For example, if several motion sensors each report a room as either “occupied” or “empty”, the mode tells you what the majority of sensors agree on. It also works with numeric values, such as finding the most common brightness setting across a group of lights.
Usage
{{ statistical_mode(21, 22, 21, 23, 21) }}
21
Function signature
statistical_mode(
*args: list | float,
default: Any = None,
) -> float
Function parameters
Using a default value
If the list might be empty or contain invalid values, provide a default to avoid errors. This prevents your templateA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more] from breaking when a sensor is temporarily unavailable.
[states("sensor.maybe_broken") | float(none)]
| reject("none")
| list
| statistical_mode(default=0)
0
Good to know
- When multiple values are tied for the highest frequency, the first one encountered wins.
- Works with any hashable type, not only numbers. Strings like
"on"and"off"are valid inputs too.
Try it yourself
More examples
Most common temperature reading
Find the most frequently reported temperature across multiple sensors.
statistical_mode(
states("sensor.living_room_temperature") | float,
states("sensor.bedroom_temperature") | float,
states("sensor.kitchen_temperature") | float,
states("sensor.hallway_temperature") | float
21.0
Mode across a group of entities
If you have a groupGroups are a way to organize your entities into a single unit. [Learn more] of sensors, you can expand the group and find the most common value in one expression.
expand("group.indoor_temperatures")
| map(attribute="state")
| map("float")
| statistical_mode
21.0
Still stuck?
Related template functions
Average (arithmetic mean): average - Calculates the arithmetic mean of a list of values.
Statistical median: median - Calculates the statistical median (middle value) of a list of values.
Minimum value: min - Returns the smallest value from a list of values.
Maximum value: max - Returns the largest value from a list of values.
Expand groups into entities: expand - Expands groups and zones into a sorted list of individual entity state objects.
