Replace using a regex pattern: regex_replace
The regex_replace template filter replaces all occurrences of a regular expression (regex) pattern in a string with a replacement value. A regular expression is a special text pattern that describes what you are looking for; regex_replace finds every part of the string that matches and swaps it out. This works like a find-and-replace tool, but with the power of patterns instead of fixed text.
This is useful when you need to clean up or transform text from sensorsSensors return information about a thing, for instance the level of water in a tank. [Learn more] and other sources. For example, you might want to strip unwanted characters from a sensor value, reformat a phone number, remove units from a measurement string so you can convert it to a number, or clean up device names for display on a dashboard.
Usage
{{ "Hello 123 World 456" | regex_replace("\\d+", "N") }}
Hello N World N
Function signature
regex_replace(
value: str,
find: str = "",
replace: str = "",
ignorecase: bool = False,
) -> str
Function parameters
The string to replace each match with. Can be empty to remove matches entirely.
Removing matched text
Pass an empty string as the replacement to remove all matches from the string.
{{ "Temperature: 23.5 C" | regex_replace("[^0-9.]", "") }}
23.5
Case-insensitive replacement
Set ignorecase to true to match and replace regardless of upper or lowercase letters.
"Error: DEVICE offline"
| regex_replace("error", "Warning", ignorecase=true)
Warning: DEVICE offline
Good to know
- Replaces every occurrence, not just the first one.
- Backreferences in the replacement use
\1,\2, and so on, to refer to capturing groups from the pattern. - Passing an empty replacement deletes every match from the string.
Try it yourself
More examples
Strip units from a sensor value
Remove non-numeric characters from a sensor state so you can use it as a number.
{{ states("sensor.wind_speed") | regex_replace("[^0-9.]", "") | float }}
15.3
Clean up a device name for display
Remove unwanted prefixes or suffixes from a device name.
"MQTT - Living Room Sensor [v2]"
| regex_replace("^MQTT - ", "")
| regex_replace("\\s*\\[.*\\]$", "")
Living Room Sensor
Mask sensitive information
Replace digits in a phone number or account number for display purposes.
{{ "+1-555-123-4567" | regex_replace("\\d(?=\\d{4})", "*") }}
+*-***-***-4567
Still stuck?
Related template functions
Match a regex pattern: regex_match - Tests if a string matches a regular expression pattern at the beginning.
Search for a regex pattern: regex_search - Searches for a regular expression pattern anywhere in a string.
Find all regex matches: regex_findall - Finds all occurrences of a regular expression pattern in a string and returns them as a list.
Find regex match at index: regex_findall_index - Finds all occurrences of a regex pattern and returns the match at a specific index.
