Match a regex pattern: regex_match
The regex_match template filter tests whether a string matches a regular expression (regex) pattern at the beginning of the string. A regular expression is a special text pattern that lets you describe what you are looking for, for example “any number” or “a word followed by a space”. It returns true if the beginning of the string matches the pattern, and false otherwise.
This is useful when you need to check whether a sensor value, entity ID, or other text starts with a specific pattern. For example, you might want to verify that a sensor value looks like a valid IP address, check if an entity ID starts with a certain prefix, or validate that an input follows an expected format. Because it only checks from the start of the string, use regex_search if you need to find a pattern anywhere in the text.
Usage
{{ "light.living_room" | regex_match("light\\.") }}
true
Function signature
regex_match(
value: str,
find: str = "",
ignorecase: bool = False,
) -> bool
Function parameters
Match vs search
regex_match only checks if the pattern matches at the beginning of the string. If you need to find a pattern anywhere in the string, use regex_search instead.
{{ "Room: Living Room" | regex_match("Living") }}
{{ "Room: Living Room" | regex_search("Living") }}
false
true
Case-insensitive matching
Set ignorecase to true to match regardless of upper or lowercase letters.
{{ "Light.living_room" | regex_match("light", ignorecase=true) }}
true
Good to know
- Only checks the start of the string. Use
regex_searchto match anywhere. - A literal dot (
.) must be escaped as\.because.matches any character in regex.
Try it yourself
More examples
Check if an entity ID belongs to a domain
Verify that an entity ID starts with a specific domain prefix.
{% set entity = "sensor.outdoor_temperature" %}
{% if entity | regex_match("sensor\\.") %}
This is a sensor entity
{% endif %}
Validate a sensor value format
Check if a sensor value looks like a valid number with optional decimal point.
{{ states("sensor.temperature") | regex_match("^-?\\d+\\.?\\d*$") }}
true
Still stuck?
Related template functions
Search for a regex pattern: regex_search - Searches for a regular expression pattern anywhere in a string.
Replace using a regex pattern: regex_replace - Replaces all occurrences of a regular expression pattern in a string.
Find all regex matches: regex_findall - Finds all occurrences of a regular expression pattern in a string and returns them as a list.
Find regex match at index: regex_findall_index - Finds all occurrences of a regex pattern and returns the match at a specific index.
Test if string matches pattern: match - Template test that checks if a string matches a regular expression at the beginning.
