Find all regex matches: regex_findall
The regex_findall template filter finds all occurrences of a regular expression (regex) pattern in a string and returns them as a list. A regular expression is a special text pattern that lets you describe what you are looking for. While regex_search just tells you whether a pattern exists, regex_findall collects every match and gives them all back to you.
This is useful when you need to extract multiple pieces of data from a text value. For example, you might want to pull all numbers out of a sensor’s state string, extract all IP addresses from a log message, or collect all entity IDs mentioned in a text attribute. The result is a list, so you can count the matches, loop through them, or pick a specific one by index.
Usage
{{ "Living room 23.5C, Bedroom 19.8C" | regex_findall("\\d+\\.\\d+") }}
['23.5', '19.8']
Function signature
regex_findall(
value: str,
find: str = "",
ignorecase: bool = False,
) -> list[str]
Function parameters
Counting matches
Since the result is a list, you can use the length filter to count how many matches were found.
"error at 10:15, error at 11:30, error at 12:45"
| regex_findall("error") | length
3
Good to know
- Returns an empty list when nothing matches, not
Noneor an error. - Capturing groups change the output: with one group, you get strings; with multiple groups, you get tuples.
- A literal dot in the pattern must be escaped as
\., since.matches any character in regex.
Try it yourself
More examples
Extract all numbers from a sensor state
Pull every number out of a text-based sensor value for processing.
{% set values = "Power: 150W, Voltage: 230V, Current: 0.65A"
| regex_findall("\\d+\\.?\\d*") %}
{{ values }}
['150', '230', '0.65']
List all matching words
Find all words in a string that start with a capital letter.
{{ "The Living Room Light is On" | regex_findall("[A-Z][a-z]+") }}
['The', 'Living', 'Room', 'Light', 'On']
Loop through extracted values
Extract all temperature values from a multi-sensor string and display them.
{% set temps = "Kitchen 21C, Hall 19C, Office 22C"
| regex_findall("(\\w+) (\\d+)C") %}
{% for room, temp in temps %}
{{ room }}: {{ temp }}C
{% endfor %}
Kitchen: 21C
Hall: 19C
Office: 22C
Still stuck?
Related template functions
Find regex match at index: regex_findall_index - Finds all occurrences of a regex pattern and returns the match at a specific index.
Match a regex pattern: regex_match - Tests if a string matches a regular expression pattern at the beginning.
Search for a regex pattern: regex_search - Searches for a regular expression pattern anywhere in a string.
Replace using a regex pattern: regex_replace - Replaces all occurrences of a regular expression pattern in a string.
