Test if number: number
The number test checks whether a value is a number, meaning either an integer or a float. It returns true for both types and false for anything else, including numeric strings.
This test checks the Python type of the value, not whether a string can be parsed as a number. If you need to check whether a string like 21.5 can be converted to a number, use is_number instead. The number test is useful when you already have a value from a calculation or attribute and want to confirm it is numeric before proceeding.
Usage
As a test
{% if 42 is number %}
  It is a number
{% endif %}
It is a number
Function signature
number(
    value: Any,
) -> bool
Function parameters
The following parameters can be provided to this test.
value any Required
The value to test. Returns true if the value is an integer or float.
Good to know
  • This checks the Python type. Numeric strings like "21.5" do not pass.
  • To test whether a value can be parsed as a number, use is_number instead.
Try it yourself
More examples
Check various types
Both integers and floats pass the number test, but strings do not.
{{ 42 is number }}
{{ 21.5 is number }}
{{ "42" is number }}
true
true
false
Validate attribute values
Check that an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] attribute is a numeric type before doing math.
{% set brightness = state_attr("light.living_room", "brightness") %}
{% if brightness is number %}
  Brightness: {{ (brightness / 255 * 100) | round(0) }}%
{% else %}
  Brightness unknown
{% endif %}
Brightness: 75%
Still stuck?
Tip
Related template functions
