Merge action responses: merge_response
The merge_response template function takes the response dictionary from a multi-entity action call and merges it into a single flat list. When you call an action that targets multiple entitiesAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more], the response is a dictionary keyed by entity ID, where each value contains the entity’s response data. merge_response flattens this structure into a single list, adding the entity_id to each item for reference.
This is useful when you call actions like calendar.get_events or weather.get_forecasts that target multiple entities at once. Without merge_response, you would need to manually loop through the response dictionary and extract items from each entity. This function handles that for you and produces a unified list that is straightforward to sort, filter, and display. Each item in the result includes an entity_id field so you can still tell which entity it came from.
Usage
As a function
{{ merge_response(response) }}
  {"start": "2024-03-15", "summary": "Meeting", "entity_id": "calendar.work"},
  {"start": "2024-03-15", "summary": "Dentist", "entity_id": "calendar.personal"},
Function signature
merge_response(
    value: dict,
) -> list
Function parameters
value map Required
The action response dictionary to merge. This must be a dictionary where each key is an entity ID and each value is a dictionary containing the entity’s response data.
Good to know
  • Adds an entity_id field to each item, so you can tell which entity each response came from after merging.
  • Only works on responses shaped as {entity_id: {key: [items]}}. Responses with a different shape need manual handling.
Try it yourself
More examples
Merge calendar events from multiple calendars
Call calendar.get_events targeting multiple calendars and merge all events into a single sorted list.
action:
  - action: calendar.get_events
      entity_id:
        - calendar.work
        - calendar.personal
      duration:
        hours: 24
    response_variable: agenda
  - action: notify.mobile
      message: >
        Today's events:
        {% for event in merge_response(agenda) | sort(attribute="start") %}
        - {{ event.summary }} ({{ event.entity_id.split(".")[1] }})
        {% endfor %}
Merge weather forecasts
Combine forecasts from multiple weather entities into one list for comparison.
action:
  - action: weather.get_forecasts
      entity_id:
        - weather.home
        - weather.office
      type: daily
    response_variable: forecasts
      message: >
        {% for item in merge_response(forecasts) %}
        {{ item.entity_id }}: {{ item.temperature }}C
        {% endfor %}
Still stuck?
Tip
Related template functions
