Get label ID: label_id
The label_id template function returns the unique labelLabels in Home Assistant allow grouping elements irrespective of their physical location or type. Labels can be assigned to areas, devices, entities, automations, scenes, scripts, and helpers. Labels can be used in automations and scripts as a target for actions. Labels can also be used to filter data. [Learn more] ID for a given label name. Every label in Home Assistant has an internal ID that stays the same even if you rename the label, and this function lets you look it up from the human-readable name.
This is useful when you need the label ID to pass to other label functions like label_areas, label_devices, or label_entities. For example, you could use it in an automationAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] to dynamically find all entitiesAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] or devicesA device is a model representing a physical or logical unit that contains entities. with a particular label by name, without needing to know the internal ID ahead of time.
Usage
{{ label_id("Critical") }}
critical
Function signature
label_id(
    lookup_value: str,
) -> str | None
Function parameters
lookup_value string Required
The name of the label to look up. Returns the matching label ID, or None if no label with that name exists. You can find labels in Settings > Areas, labels & zones.
Good to know
  • Returns None when no label matches the name.
  • The match is case-sensitive. "critical" does not match a label named "Critical".
Try it yourself
More examples
Look up a label ID by name
Find the internal ID of a label using its friendly name.
{{ label_id("Energy Monitoring") }}
energy_monitoring
Use label ID to find all entities with that label
Combine label_id with label_entities to find all entities that have a specific label, using the label’s friendly name.
{{ label_entities(label_id("Critical")) }}
  "sensor.living_room_temperature",
  "binary_sensor.front_door",
Still stuck?
Tip
Related template functions
