Get devices with a label: label_devices
The label_devices template function returns a list of deviceA device is a model representing a physical or logical unit that contains entities. IDs that have a specific labelLabels in Home Assistant allow grouping elements irrespective of their physical location or type. Labels can be assigned to areas, devices, entities, automations, scenes, scripts, and helpers. Labels can be used in automations and scripts as a target for actions. Labels can also be used to filter data. [Learn more] assigned. You can specify the label by its name or by its internal ID. This gives you all devices tagged with that label.
This is useful when you organize your devices using labels and want to act on or inspect a specific group. For example, if you label battery-powered devices as “Battery”, you could use label_devices to find them all and check their battery levels, or if you label certain devices as “Guest Room”, you could quickly find and control all devices for your guests. As you add or remove labels from devices, the list automatically updates, so your automationsAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] and templatesA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more] always reflect the current state.
Usage
{{ label_devices("Battery") }}
"a1b2c3d4e5f6a1b2c3d4e5f6",
"f6e5d4c3b2a1f6e5d4c3b2a1",
Function signature
label_devices(
label_id_or_name: str,
) -> list[str]
Function parameters
The label name or ID to look up. Returns the device IDs that have this label assigned. You can find labels in Settings > Areas, labels & zones.
Good to know
- Only returns devices with the label assigned directly. Labels applied to entities or areas do not roll up to their devices.
- Returns an empty list when the label does not match any devices.
Try it yourself
More examples
Count devices with a specific label
Find out how many devices are tagged with a given label.
{{ label_devices("Battery") | count }}
2
Get device names for a label
List the friendly names of all devices that have a specific label by combining label_devices with device_name.
{% for device_id in label_devices("Battery") %}
{{ device_name(device_id) }}
{% endfor %}
Living Room Motion Sensor
Front Door Sensor
Check battery levels of labeled devices
Find all devices with a “Battery” label and check their battery sensor entities. This collects the battery-level entities for all labeled devices.
{% set batteries = device_entities(device_id)
| select("match", "sensor.")
| select("search", "battery")
| list %}
{% for entity_id in batteries %}
{{ device_name(device_id) }}: {{ states(entity_id) }}%
{% endfor %}
{% endfor %}
Living Room Motion Sensor: 85%
Front Door Sensor: 42%
Still stuck?
Related template functions
Get areas with a label: label_areas - Returns a list of area IDs that have a specific label assigned.
Get entities with a label: label_entities - Returns a list of entity IDs that have a specific label assigned.
Get all labels: labels - Returns a list of all label IDs, or the labels assigned to a specific entity, device, or area.
Get label ID: label_id - Returns the label ID for a given label name.
Get label name: label_name - Returns the friendly name of a label from its ID.
