Get label description: label_description
The label_description template function returns the description text of a labelLabels in Home Assistant allow grouping elements irrespective of their physical location or type. Labels can be assigned to areas, devices, entities, automations, scenes, scripts, and helpers. Labels can be used in automations and scripts as a target for actions. Labels can also be used to filter data. [Learn more] from its internal ID. When you create a label in Home Assistant, you can optionally give it a description that explains its purpose, and this function lets you retrieve that description.
This is useful when you want to display additional context about a label beyond its name. For example, if you have a label called “Critical” with a description like “Sensors that trigger emergency alerts”, you could display that description in a dashboard or use it in notificationsYou can use notifications to send messages, pictures, and more, to devices. [Learn more] to provide more context. If the label has no description set, the function returns None.
Usage
{{ label_description("critical") }}
Function signature
label_description(
    lookup_value: str,
) -> str | None
Function parameters
lookup_value string Required
The label ID to look up. Returns the description of the label, or None if no label with that ID exists or the label has no description.
Good to know
  • Returns None when the label does not exist or has no description.
  • Only accepts a label ID, not a label name. Resolve a name with label_id first.
Try it yourself
More examples
Display a label’s description
Retrieve the description text for a specific label.
{{ label_description("energy_monitoring") }}
Devices and sensors used for tracking energy usage
List labels with their descriptions
Loop through all labels and display their names along with descriptions, using labels and label_name.
{% for lbl_id in labels() %}
  {{ label_name(lbl_id) }}: {{ label_description(lbl_id) }}
{% endfor %}
Outdoor: Items located outside the house
Critical: Sensors that trigger emergency alerts
Energy Monitoring: Devices and sensors used for tracking energy usage
Still stuck?
Tip
Related template functions
