Test if value is numeric: is_number
The is_number template function tests whether a value can be converted to a valid, finite floating-point number. It returns true if the value is numeric and false otherwise. Values like infinity and NaN are not considered numbers and return false.
This is a safety check you should use before performing math on values that might not be numeric. EntityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] states in Home Assistant can be unavailable, unknown, or other non-numeric strings at any time. Trying to do math on these values without checking first causes errors. By testing with is_number first, you can branch your logic to handle numeric and non-numeric cases separately. It is also useful as a template test in {% if %} blocks.
Usage
{{ is_number("21.5") }}
true
Function signature
is_number(
value: Any,
) -> bool
Function parameters
What counts as a number
The function attempts to convert the value to a float. If the conversion succeeds and the result is a finite number (not infinity or NaN), it returns true.
{{ is_number(42) }}
{{ is_number("unavailable") }}
{{ is_number("inf") }}
true
true
false
false
Good to know
- Returns
falseforunavailable,unknown,infinity, andNaN, which catches common unsafe cases for math. - Booleans pass this test because Python treats
TrueandFalseas1and0. - Numeric strings like
"21.5"pass. This checks convertibility, not the current type.
Try it yourself
More examples
Guard a calculation
Only perform math if the sensor value is actually a number.
{% if states("sensor.power_usage") | is_number %}
{{ states("sensor.power_usage") | float * 0.25 }}
{% else %}
Sensor is not reporting a number
{% endif %}
62.5
Filter a list to only numeric values
When working with multiple sensorsSensors return information about a thing, for instance the level of water in a tank. [Learn more], filter out any that are not reporting numbers before calculating an average.
["21.5", "unavailable", "19.8", "unknown"]
| select("is_number")
| map("float")
| list
| average
20.65
Use in an automation condition
Only proceed if the sensor is reporting a valid number.
condition:
- condition: template
value_template: >
{{ states("sensor.wind_speed") | is_number }}
Still stuck?
Related template functions
Convert to float: float - Converts a value to a floating-point number, with an optional default if conversion fails.
Convert to integer: int - Converts a value to an integer, with an optional default if conversion fails.
Check if entity has a value: has_value - Tests if an entity exists and has a valid state (not unavailable or unknown).
Get the type of a value: typeof - Returns the type name of a value as a string.
