Test device attribute: is_device_attr
The is_device_attr template function checks whether a specific attribute of a deviceA device is a model representing a physical or logical unit that contains entities. matches a given value. It returns true or false. This is the device-level equivalent of is_state_attr, working with the device registry instead of entity states.
This is useful when you want to make decisions in automationsAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] or templatesA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more] based on device properties. For example, you could check if a device is made by a specific manufacturer, runs a particular firmware version, or matches a certain model. You might use it to apply different logic depending on the hardware vendor, or to trigger an alert when a device’s software version doesn’t match the expected value after an update.
Usage
{{ is_device_attr("a1b2c3d4e5f6a1b2c3d4e5f6", "manufacturer", "Philips") }}
true
Function signature
is_device_attr(
device_or_entity_id: str,
attr_name: str,
attr_value: Any,
) -> bool
Function parameters
The device ID or entity ID to check. When using an entity ID, the function first resolves the device the entity belongs to.
The name of the device attribute to test. Common attributes include manufacturer, model, sw_version, hw_version, and serial_number.
Good to know
- Returns
false(not an error) when the device or attribute does not exist. - String comparison is case-sensitive.
is_device_attr(id, "manufacturer", "philips")does not match"Philips". - Accepts either a device ID or an entity ID. With an entity ID, the device is resolved first.
Try it yourself
More examples
Check if a device is a specific model
Verify that a device matches an expected model, for example to apply model-specific logic in an automation.
{{ is_device_attr("light.living_room", "model", "LCA001") }}
true
Use in an automation condition
Only run the rest of the automationAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] if the device is from a specific manufacturer.
condition:
- condition: template
value_template: >
{{ is_device_attr("sensor.front_door", "manufacturer", "Aqara") }}
Check firmware version across devices in an area
Combine with area_devices to find devices in an area that are running a specific firmware version.
{% for dev_id in area_devices("Living Room") %}
{% if is_device_attr(dev_id, "sw_version", "1.104.2") %}
{{ device_name(dev_id) }}
{% endif %}
{% endfor %}
Still stuck?
Related template functions
Get device attribute: device_attr - Returns the value of a specific attribute from a device.
Get a device ID: device_id - Returns the device ID for a given entity ID or device name.
Get a device name: device_name - Returns the name of a device from a device ID or entity ID.
Get entities for a device: device_entities - Returns a list of entity IDs associated with a given device.
