Get entities for an integration: integration_entities
The integration_entities template function returns a list of entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] IDs that belong to a specific integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] or config entry. You can pass either a domain name (like hue) to get all entities for that integration, or a config entry title (like Living Room Hue Bridge) to narrow it down to a specific instance.
This is especially useful when you have multiple instances of the same integration and need to work with entities from only one of them. For example, if you have two Hue bridges, you can get the entities for each one separately by using their config entry titles. You can also use this to count how many entities an integration has created, or to check the state of all entities that belong to a particular integration at once.
Usage
{{ integration_entities("hue") }}
  "light.living_room",
  "light.bedroom",
  "sensor.hue_motion",
Function signature
    entry_name: str,
) -> list[str]
Function parameters
entry_name string Required
The integration domain name (for example, hue) or config entry title (for example, Living Room Hue Bridge). When a config entry title matches, only entities from that specific config entry are returned. Otherwise, all entities for the domain are returned.
Good to know
  • A domain name returns entities from every config entry of that integration. Use a config entry title to narrow down to one instance.
  • Config entry title matches take precedence over domain matches, so a title that looks like a domain name is matched first as a title.
  • Returns an empty list when nothing matches, rather than raising an error.
Try it yourself
More examples
Count entities for an integration
Find out how many entities a specific integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] has registered.
{{ integration_entities("zwave_js") | count }}
Result (integerA whole number without decimal places, like 1, 42, or -5. Used for counts, indices, and whole values.)
42
Check if any entity from an integration is unavailable
Loop through all entities from an integration and check if any are in the unavailable state.
  integration_entities("mqtt")
  | select("is_state", "unavailable")
  | list
  | count > 0
false
Get entities from a specific config entry
When you have multiple instances of the same integration, use the config entry title to get entities for only one of them.
{{ integration_entities("Living Room Hue Bridge") }}
  "light.living_room_ceiling",
  "light.living_room_lamp",
Still stuck?
Tip
Related template functions
