Test if integer: integer
The integer test checks whether a value is an integer. It returns true if the value is of integer type and false for any other type, including floats and strings that contain numeric characters.
This test is useful when you need to verify that a value is specifically an integer rather than a float or string. For example, some entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] attributes return integers for discrete counts (like the number of connected devices) while others return floats for measurements. This test lets you confirm the type before proceeding with type-specific logic.
Usage
As a test
{% if 42 is integer %}
  It is an integer
{% endif %}
It is an integer
Function signature
integer(
    value: Any,
) -> bool
Function parameters
The following parameters can be provided to this test.
value any Required
The value to test. Returns true if the value is of integer type.
Good to know
  • Booleans pass this test because True and False are integers in Python. Guard with is not boolean if that matters.
  • Numeric strings like "42" do not pass. Convert with int first.
Try it yourself
More examples
Distinguish integer from float
Check whether a numeric value is specifically an integer.
{{ 42 is integer }}
{{ 42.0 is integer }}
{{ "42" is integer }}
true
false
false
Validate before integer operations
Ensure a value is an integer before using it in an operation that requires whole numbers.
{% set count = state_attr("sensor.devices", "count") %}
{% if count is integer %}
  {{ count }} devices connected
{% else %}
  Invalid count
{% endif %}
5 devices connected
Still stuck?
Tip
Related template functions
