Test if in sequence: in
The in test checks whether a value is contained in a given sequence (list, tuple, or string). It returns true if the value is found and false otherwise. Use value is in(sequence) to perform the check.
This test is useful when you want to check if an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] state matches one of several possible values, or when filtering collections. While you can use Python’s in operator directly in conditions (if state in ["on", "off"]), the in test can be used with filters like select and reject that expect a test name.
Usage
As a test
{% if "on" is in(["on", "off", "idle"]) %}
  Found in list
{% endif %}
Found in list
Function signature
in(
    value: Any,
    seq: Sequence,
) -> bool
Function parameters
The following parameters can be provided to this test.
value any Required
The value to search for in the sequence.
seq list Required
The sequence (list, tuple, or string) to search in.
Good to know
  • String membership is case-sensitive. "ON" is in(["on", "off"]) is false.
  • On a string, this checks for substring presence rather than whole-word matching.
  • Unlike Python’s in operator, this is a Jinja test, so it works as a filter argument in select and reject.
Try it yourself
More examples
Check if state is one of several values
Verify that a sensorSensors return information about a thing, for instance the level of water in a tank. [Learn more] state matches an expected set of values.
{% set state = states("climate.thermostat") %}
{% if state is in(["heat", "cool", "auto"]) %}
  Climate is active: {{ state }}
{% else %}
  Climate is idle
{% endif %}
Climate is active: heat
Check for substring in a string
The in test also works with strings, checking for substring membership.
{{ "error" is in("Connection error occurred") }}
true
Still stuck?
Tip
Related template functions
