Parse JSON string: from_json
The from_json filter takes a JSON-formatted string and parses it into a Python object (dictionary, list, string, number, or boolean). This is the opposite of to_json, which converts an object into a JSON string.
This is essential when working with data received from external services. Many integrations store JSON data as strings in entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] states or attributes. For example, MQTT messages, REST sensor responses, and webhook payloads often arrive as JSON strings that you need to parse before you can access individual values. Once parsed, you can use standard dictionary and list operations to extract the data you need. The optional default parameter lets you provide a fallback value if the JSON is invalid, preventing errors in your templatesA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more].
Usage
As a filter
{{ '{"temperature": 21.5, "humidity": 45}' | from_json }}
Result (dict)
{'temperature': 21.5, 'humidity': 45}
Function signature
value | from_json(
    default: Any = <raises error>,
) -> Any
Function parameters
default any (Optional)
Value to return if the JSON string is invalid or cannot be parsed. If not provided, an error is raised on invalid input.
Using a default value
If the input might not be valid JSON, provide a default to avoid errors.
{{ "not valid json" | from_json(default={}) }}
Result (dict)
Good to know
  • Without a default, invalid JSON raises an error that can break your template.
  • JSON uses double quotes only. Single-quoted strings like '{"a": 1}' need to wrap a string that itself uses double quotes inside.
  • Returns the matching Python type: an object becomes a dict, an array becomes a list, null becomes None.
Try it yourself
More examples
Parse an MQTT message
Extract a value from a JSON-formatted MQTT sensor payload.
{% set payload = states("sensor.mqtt_sensor") | from_json %}
Temperature: {{ payload.temperature }}
Humidity: {{ payload.humidity }}
Temperature: 21.5
Humidity: 45
Parse a REST sensor response
Access nested data from a REST API response stored as a JSON string.
{% set data = states("sensor.api_response") | from_json %}
{{ data.results | map(attribute="name") | list }}
["Item A", "Item B", "Item C"]
Safe parsing with a default
When processing data that might not always be valid JSON, use a default to keep your templateA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more] working.
{% set data = states("sensor.maybe_json")
   | from_json(default={"status": "unknown"}) %}
Status: {{ data.status }}
Status: unknown
Still stuck?
Tip
Related template functions
