Decode hex string to bytes: from_hex
The from_hex filter converts a hexadecimal string into a bytes object. Each pair of hex characters in the input string is converted to a single byte. For example, “48656c6c6f” decodes to the bytes representing “Hello”.
This is useful when working with IoT devicesA device is a model representing a physical or logical unit that contains entities. and protocols that represent binary data as hex strings. Many BLE (Bluetooth Low Energy) sensorsSensors return information about a thing, for instance the level of water in a tank. [Learn more], Zigbee devices, and serial protocols report their data as hexadecimal strings. The from_hex filter converts these hex strings into bytes that you can then process further with unpack to extract numeric values, or decode to a text string.
Usage
As a filter
{{ "48656c6c6f" | from_hex }}
Result (bytes)
b'Hello'
Function signature
value | from_hex() -> bytes
Function parameters
value string Required
The hexadecimal string to decode. Must contain an even number of hex characters (0-9, a-f, A-F).
Good to know
  • The input must have an even number of hex characters. Odd-length strings raise an error.
  • The result is raw bytes. Pipe to string for text, or unpack for numeric values.
  • A 0x prefix on the input raises an error; strip it first.
Try it yourself
More examples
Decode a hex sensor value to an integer
Convert a hex string from a sensor into an integer using unpack.
{{ "04d2" | from_hex | unpack(">H") }}
Result (integerA whole number without decimal places, like 1, 42, or -5. Used for counts, indices, and whole values.)
1234
Decode hex to a text string
Convert a hex-encoded string to readable text by decoding the resulting bytes.
{{ "486f6d65" | from_hex | string }}
Home
Process BLE advertisement data
Extract a temperature value from a BLE sensor that reports data as a hex string. The first two bytes (4 hex characters) contain the temperature as a big-endian signed short.
{% set hex_data = states("sensor.ble_advertisement") %}
{{ hex_data[:4] | from_hex | unpack(">h") / 100 }}
Result (floatA number that can have decimal places, like 21.5 or 3.14. Used for temperatures, percentages, and other measurements that need precision.)
21.5
Still stuck?
Tip
Related template functions
