Test if float: float
The float test checks whether a value is a floating-point number. It returns true if the value is of float type and false for any other type, including integers and numeric strings.
This is useful when you need to verify the exact type of a numeric value. In Home Assistant, calculations often produce floats, and some entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] attributes are specifically floating-point values. This test lets you distinguish between integers and floats when the difference matters for your template logic.
Usage
{% if 21.5 is float %}
It is a float
{% endif %}
It is a float
Function signature
float(
value: Any,
) -> bool
Function parameters
The following parameters can be provided to this test.
Good to know
- Only true float values pass. Integers, numeric strings, and booleans do not.
- To accept any numeric input, use the
numbertest instead.
Try it yourself
More examples
Distinguish float from integer
Check whether a numeric value is a float rather than an integer.
{{ 21.5 is float }}
{{ 42 is float }}
{{ "21.5" is float }}
true
false
false
Check calculation result type
Verify the type of a calculation result before formatting it.
{% set result = 10 / 3 %}
{% if result is float %}
Result: {{ result | round(2) }}
{% endif %}
Result: 3.33
Still stuck?
Related template functions
Convert to float: float - Converts a value to a floating-point number, with an optional default if conversion fails.
Get the type of a value: typeof - Returns the type name of a value as a string.
