Test if false: false
The false test checks whether a value is false. It performs a strict identity check, meaning only the boolean value false passes. Values like 0, "", none, and the string "false" do not match.
This is useful when you need to verify that a value is specifically the boolean false and not merely a falsy value. In Home Assistant, entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] attributes can be actual booleans, and this test lets you check for an exact false value without accidentally matching other falsy types like 0 or an empty string.
Usage
As a test
{% if false is false %}
  It is false
{% endif %}
It is false
Function signature
false(
    value: Any,
) -> bool
Function parameters
The following parameters can be provided to this test.
value any Required
The value to test. Returns true only if the value is the boolean false.
Good to know
  • This is a strict identity test. Only the boolean false passes, while 0, empty strings, and None do not.
  • Entity states are strings, so states("switch.x") is false is always false. Use is_state("switch.x", "off") instead.
Try it yourself
More examples
Strict boolean check
Only the boolean false passes; falsy values like 0 or `` do not.
{{ false is false }}
{{ 0 is false }}
{{ "" is false }}
true
false
false
Verify a boolean attribute
Check that an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] attribute is specifically false.
{% set charging = state_attr("sensor.phone", "is_charging") %}
{% if charging is false %}
  Phone is not charging
{% endif %}
Still stuck?
Tip
Related template functions
