Get a device ID: device_id
The device_id template function returns the deviceA device is a model representing a physical or logical unit that contains entities. ID associated with an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] ID or a device name. If you pass an entity ID, it looks up which device that entity belongs to. If you pass a device name, it searches for a device with that exact name. It returns None if no matching device is found.
This is the starting point for most device-related template work. Since many device functions require a device ID, you’ll often use device_id to get that ID from something more human-readable. For example, you might know the entity ID of your thermostat sensor but need the device ID to look up the manufacturer or firmware version with device_attr. Or you might want to find all entities on the same device as a particular sensor using device_entities.
Usage
{{ device_id("sensor.living_room_temperature") }}
a1b2c3d4e5f6a1b2c3d4e5f6
Function signature
device_id(
entity_id_or_device_name: str,
) -> str | None
Function parameters
Good to know
- Returns
Nonewhen no device matches or when the entity does not belong to a device. - Name lookups need an exact match, including capitalization and spaces.
- When you set a custom device name, that name takes precedence over the default device name.
Try it yourself
More examples
Look up a device ID by device name
You can also pass a device name instead of an entity ID. This is handy when you know the name of the device but not its ID.
{{ device_id("Living Room Thermostat") }}
Chain with device_entities to find sibling entities
Find all entities that share the same device as a known entity. This is useful when you know one entity on a device and want to discover the rest.
| device_entities
"sensor.living_room_temperature",
"sensor.living_room_humidity",
"binary_sensor.living_room_battery",
Get the manufacturer of a device from an entity ID
Combine device_id with device_attr to look up device attributes starting from an entity ID.
device_attr(
device_id("sensor.living_room_temperature"),
"manufacturer"
Aqara
Still stuck?
Related template functions
Get entities for a device: device_entities - Returns a list of entity IDs associated with a given device.
Get a device name: device_name - Returns the name of a device from a device ID or entity ID.
Get device attribute: device_attr - Returns the value of a specific attribute from a device.
Test device attribute: is_device_attr - Tests if a specific attribute of a device has a given value.
