Get entities for a device: device_entities
The device_entities template function returns a list of entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] IDs that belong to a given deviceA device is a model representing a physical or logical unit that contains entities.. You pass it a device ID, and it gives you every entity that is tied to that device in Home Assistant.
This is useful when you want to work with all the entities that a single device provides. For example, a smart plug might expose a switch entity, an energy sensor, and a signal strength sensor. With device_entities, you can loop through all of those at once. You could use it to check if any entity on a device is unavailable, build a summary card for a specific device, or find all sensors on a particular piece of hardware.
Tip
The device’s page in Settings > Devices & services lists all entities that belong to it. Reach for device_entities() when you need that list inside a template expression.
Usage
{{ device_entities("a1b2c3d4e5f6a1b2c3d4e5f6") }}
  "switch.smart_plug",
  "sensor.smart_plug_energy",
  "sensor.smart_plug_signal",
Function signature
device_entities(
    device_id: str,
) -> list[str]
Function parameters
device_id string Required
The ID of the device. You can find device IDs by using the device_id function with an entity ID or device name.
Good to know
  • Returns an empty list when the device ID does not match. It does not raise an error.
  • Only accepts a device ID, not an entity ID or device name. Use device_id to resolve those first.
  • Hidden and disabled entities are included in the result.
Try it yourself
More examples
Count entities on a device
Find out how many entities a specific device has registered.
{{ device_entities("a1b2c3d4e5f6a1b2c3d4e5f6") | count }}
Result (integerA whole number without decimal places, like 1, 42, or -5. Used for counts, indices, and whole values.)
3
Check if any entity on a device is unavailable
This checks whether any entity belonging to a device is currently in an unavailable state. Useful for monitoring device health.
  | select("is_state", "unavailable")
  | list
  | count > 0
false
Get all sensor entities from a device
Filter the device’s entities to only include sensors.
  | select("match", "sensor.")
  | list
Still stuck?
Tip
Related template functions
