Get config entry ID: config_entry_id
The config_entry_id template function returns the config entry ID that an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] belongs to. Every entity that is created by an integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] is tied to a config entry, and this function lets you look up that connection. It returns None if the entity does not exist in the registry.
This is useful when you need to look up details about the config entry behind an entity using config_entry_attr. For example, you might want to find out which integration domain an entity came from, check whether the config entry is still active, or group entities by their config entry. It is also helpful for debugging, letting you trace an entity back to the configuration that created it.
Usage
{{ config_entry_id("light.living_room") }}
01234567890abcdef01234567890abcd
Function signature
config_entry_id(
    entity_id: str,
) -> str | None
Function parameters
entity_id string Required
The entity ID to look up. Returns the config entry ID as a string, or None if the entity does not exist in the registry.
Good to know
  • Returns None for helper entities and YAML-configured entities, which have no config entry.
  • Returns None when the entity does not exist in the registry yet, which can happen right after creation.
Try it yourself
More examples
Find the integration domain for an entity
Combine config_entry_id with config_entry_attr to find out which integration domain an entity belongs to.
{{ config_entry_attr(config_entry_id("light.living_room"), "domain") }}
hue
Check if an entity’s config entry is loaded
Verify that the config entry behind an entity is in the loaded state, which means the integration is running normally.
  config_entry_attr(
    config_entry_id("sensor.power_meter"), "state"
loaded
Still stuck?
Tip
Related template functions
