Test if boolean: boolean
The boolean test checks whether a value is a boolean (true or false). It returns true if the value is of boolean type and false for any other type, including strings like true or integers like 1.
This is useful when you need to verify the type of a value before processing it. In Home Assistant, entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] states are always strings, but attributes can be actual booleans. If you need to distinguish between a real boolean and a string that looks like one, this test lets you check the actual type.
Usage
{% if true is boolean %}
It is a boolean
{% endif %}
It is a boolean
Function signature
boolean(
value: Any,
) -> bool
Function parameters
The following parameters can be provided to this test.
Good to know
- Only the actual boolean values
trueandfalsepass this test. Strings like"true"and integers like1do not. - Entity states are always strings, so this test will never succeed on a raw
states(...)result.
Try it yourself
More examples
Distinguish boolean from string
Check whether a value is actually a boolean and not a string representation.
{{ true is boolean }}
{{ "true" is boolean }}
true
false
Validate an attribute type
Verify that an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] attribute is a real boolean before using it directly.
{% set val = state_attr("switch.device", "is_locked") %}
{% if val is boolean %}
Lock state: {{ val }}
{% else %}
Unexpected type
{% endif %}
Lock state: True
Still stuck?
Related template functions
Convert to boolean: bool - Converts a value to a boolean (true/false), with an optional default if conversion fails.
Get the type of a value: typeof - Returns the type name of a value as a string.
