Bitwise XOR: bitwise_xor
The bitwise_xor template function performs a bitwise XOR (exclusive OR) operation on two integer values. Each bit in the result is set to 1 only if exactly one of the corresponding bits in the input values is 1.
This is useful for toggling specific bits in a bitmask or comparing two status values to find which bits differ. For example, you could compare the current and previous status registers of a deviceA device is a model representing a physical or logical unit that contains entities. to detect which flags have changed.
Usage
{{ bitwise_xor(5, 3) }}
Result (intA whole number without decimal places, like 1, 42, or -5. Used for counts, indices, and whole values.)
6
Function signature
bitwise_xor(
    first_value: Any,
    second_value: Any,
) -> int
Function parameters
first_value integer Required
The first integer value for the XOR operation.
second_value integer Required
The second integer value for the XOR operation.
Good to know
  • Both inputs must be integers. Convert state strings with int first.
  • XOR-ing a value with itself produces zero, which is a quick way to detect whether two values are identical.
Try it yourself
More examples
Detecting changed bits
Compare two status values to find which bits changed.
{% set old_status = 0b1010 %}
{% set new_status = 0b1100 %}
{{ bitwise_xor(old_status, new_status) }}
6
Still stuck?
Tip
Related template functions
