Bitwise OR: bitwise_or
The bitwise_or template function performs a bitwise OR operation on two integer values. Each bit in the result is set to 1 if at least one of the corresponding bits in the input values is 1.
This is useful when you need to combine multiple status flags into a single value or set specific bits in a bitmask. For example, if different sensorsSensors return information about a thing, for instance the level of water in a tank. [Learn more] each report a single flag bit and you want to combine them into a single status register, bitwise_or lets you merge them together.
Usage
{{ bitwise_or(5, 3) }}
7
Function signature
bitwise_or(
first_value: Any,
second_value: Any,
) -> int
Function parameters
Good to know
- Both inputs must be integers. Convert state strings with
intfirst. - Binary literals like
0b0010work and can make bit flags more readable.
Try it yourself
More examples
Combining status flags
Combine two flag values into a single bitmask.
{% set flag_a = 0b0010 %}
{% set flag_b = 0b0100 %}
{{ bitwise_or(flag_a, flag_b) }}
6
Still stuck?
Related template functions
Bitwise AND: bitwise_and - Performs a bitwise AND operation on two values.
Bitwise XOR: bitwise_xor - Performs a bitwise XOR (exclusive OR) operation on two values.
