Bitwise AND: bitwise_and
The bitwise_and template function performs a bitwise AND operation on two integer values. Each bit in the result is set to 1 only if both corresponding bits in the input values are 1.
This is useful when working with devicesA device is a model representing a physical or logical unit that contains entities. that communicate status or configuration using bitmasks. For example, some sensorsSensors return information about a thing, for instance the level of water in a tank. [Learn more] report multiple flags packed into a single integer value, and you can use bitwise_and to check whether a specific flag bit is set. It is also helpful for masking out specific bits from a register value.
Usage
{{ bitwise_and(7, 3) }}
Result (intA whole number without decimal places, like 1, 42, or -5. Used for counts, indices, and whole values.)
3
Function signature
bitwise_and(
    first_value: Any,
    second_value: Any,
) -> int
Function parameters
first_value integer Required
The first integer value for the AND operation.
second_value integer Required
The second integer value for the AND operation.
Good to know
  • Both inputs must be integers. Convert state strings with int first.
  • To test whether a specific bit is set, compare the result to the bit mask or to zero.
Try it yourself
More examples
Checking a status bit
Check if bit 2 (value 4) is set in a sensor’s status register.
{% set status = states("sensor.device_status") | int %}
{{ bitwise_and(status, 4) > 0 }}
True
Still stuck?
Tip
Related template functions
