Encode to base64: base64_encode
The base64_encode filter converts a string or bytes value into its base64-encoded representation. Base64 encoding transforms binary data into a text format that uses only printable ASCII characters, making it safe to include in places that only support text.
This is useful when you need to send binary data or credentials through text-only channels. For example, some REST APIs require authentication headers to be base64-encoded, certain MQTT payloads need binary data encoded as text, or you might need to embed image data in a notification. The filter accepts both strings and raw bytes, encoding them into a standard base64 string.
Usage
{{ "Hello, World!" | base64_encode }}
SGVsbG8sIFdvcmxkIQ==
Function signature
value | base64_encode() -> str
Function parameters
Good to know
- Strings are encoded as UTF-8 before being base64-encoded.
- The result includes
=padding characters when the input length is not a multiple of three.
Try it yourself
More examples
Create a basic auth header
Build an HTTP Basic Authentication header by base64-encoding credentials.
{{ ("username:password") | base64_encode }}
dXNlcm5hbWU6cGFzc3dvcmQ=
Encode sensor data for transmission
Encode a sensor value for inclusion in a base64-only payload.
{{ states("sensor.temperature") | base64_encode }}
MjEuNQ==
Still stuck?
Related template functions
- Decode from base64: base64_decode - Decodes a base64-encoded string.
