Decode from base64: base64_decode
The base64_decode filter takes a base64-encoded string and decodes it back to its original form. By default, it returns a UTF-8 string, but you can set the encoding to none to get raw bytes instead.
This is useful when you receive base64-encoded data from external services or sensorsSensors return information about a thing, for instance the level of water in a tank. [Learn more]. For example, some MQTT messages include base64-encoded payloads, certain APIs return data in base64 format, or you might receive encoded credentials that need to be decoded. The optional encoding parameter lets you control how the decoded bytes are interpreted. Set it to none when working with binary data that is not a text string.
Usage
{{ "SGVsbG8sIFdvcmxkIQ==" | base64_decode }}
Hello, World!
Function signature
value | base64_decode(
encoding: str | None = "utf-8",
) -> str | bytes
Function parameters
Decoding to raw bytes
Set encoding to none to get the raw bytes instead of a string. This is useful when the encoded data is not text.
{{ "AQIDBA==" | base64_decode(encoding=none) }}
b'\x01\x02\x03\x04'
Good to know
- By default, the decoded bytes are interpreted as UTF-8. Non-UTF-8 binary data raises an error unless you pass
encoding=none. - Setting
encoding=nonereturns raw bytes, which display with ab'...'prefix and cannot be concatenated with strings directly.
Try it yourself
More examples
Decode an MQTT payload
Decode a base64-encoded message received from an MQTT topic.
{{ states("sensor.mqtt_encoded") | base64_decode }}
Temperature: 21.5C
Decode and parse JSON
Decode a base64 string that contains JSON data, then parse it.
{% set decoded = "eyJ0ZW1wIjogMjEuNX0=" | base64_decode %}
{{ decoded | from_json }}
{'temp': 21.5}
Still stuck?
Related template functions
- Encode to base64: base64_encode - Encodes a string or bytes to a base64 string.
