Turn a macro into a function: as_function
The as_function template function takes a template macro and turns it into a reusable function that produces a value. A macro on its own can only output text, which limits what you can do with its result. Wrapping it with as_function gives you a proper function you can pass to map, select, reject, or store in a variable for later use.
You reach for as_function when you’ve written a piece of reusable logic (usually in a macro) and want to run it across a list of values, or use it as a custom test. For most templates, built-in filters and functions are enough. The macro you wrap must take a special returns argument. Inside the macro, you call returns(value) to say “this is what the function should hand back”.
Usage
{% macro macro_double(value, returns) %}
  {{ returns(value * 2) }}
{% endmacro %}
{{ as_function(macro_double)(5) }}
Result (integerA whole number without decimal places, like 1, 42, or -5. Used for counts, indices, and whole values.)
10
Function signature
as_function(
    macro: Macro,
) -> Callable
Function parameters
macro any Required
A template macro that takes a returns argument. Inside the macro, call returns(value) with whatever you want the resulting function to hand back.
Writing a compatible macro
The macro must accept a returns parameter. Call returns() with the value you want the function to produce. The macro name is conventionally prefixed with macro_; this prefix is stripped from the resulting function’s name.
TemplateA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more]: Basic usage
{% macro macro_add_ten(value, returns) %}
  {{ returns(value + 10) }}
{% endmacro %}
{% set add_ten = as_function(macro_add_ten) %}
{{ add_ten(5) }}
15
Using with map
Once converted, the function works seamlessly with map to transform lists.
TemplateA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more]: Format temperatures
{% macro macro_format_temp(value, returns) %}
  {{ returns(value | round(1) ~ "°C") }}
{% endmacro %}
{% set format_temp = as_function(macro_format_temp) %}
{{ [21.456, 19.8, 22.123] | map("apply", format_temp) | list }}
['21.5°C', '19.8°C', '22.1°C']
Good to know
  • The macro must include a returns parameter and end by calling returns(value). Without that call, the function produces None.
  • The conventional macro_ name prefix is stripped from the resulting function, so macro_double becomes double.
Try it yourself
More examples
Custom filter for select
Create a function that tests whether a value is within a range, then use it with select to filter a list.
{% macro macro_in_range(value, low, high, returns) %}
  {{ returns(low <= value <= high) }}
{% endmacro %}
{% set in_range = as_function(macro_in_range) %}
{{ [15, 22, 30, 18, 25] | select("apply", in_range, 20, 26) | list }}
[22, 25]
Still stuck?
Tip
Related template functions
