Yale Home
Support for devices by Yale Home in Home Assistant is provided by the August integration.
Yale Home devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the August integration.
To add the Yale Home integration to your Home Assistant instance, use this My button:
Yale Home can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Yale Home.
Usage information
For more documentation on how to use Yale Home in Home Assistant, please refer to the August integration documentation page.
