Xbox Live
The Xbox Live integration is able to track Xbox profiles.
To use this sensor you need a free API key from XboxAPI.com. Please also make sure to connect your Xbox account on that site.
The configuration requires you to specify XUIDs which are the unique identifiers for profiles. These can be determined on XboxAPI.com by either looking at your own profile page or using their interactive documentation to search for gamertags. Sensor names default to the gamertag associated with an XUID.
To use the Xbox Live sensor in your installation,
add the following to your configuration.yaml
file:
- platform: xbox_live
api_key: YOUR_API_KEY
xuid:
- account1
- account2
- api_key
(string)(Required)
Your API key from XboxAPI.com.
- xuid
(list)(Required)
Array of profile XUIDs to be tracked.
