Victron GX
The Victron GX Integration integration connects to Victron Energy GX devices using MQTT, providing real-time monitoring and control of your Victron system, including inverters, solar chargers, battery systems, grid meters, and EV chargers.
Supported devices
This integration supports Victron Energy devices that run Venus OS and have MQTT enabled, including:
- Cerbo GX
- Venus GX
- Color Control GX
- MultiPlus inverters
- Quattro inverters
- Solar charge controllers
- Battery monitors
- EV charging stations
- A Victron Energy GX device running Venus OS with MQTT enabled.
- Network connectivity between your Home Assistant instance and the Victron device.
- For secured installations without token pairing support: the MQTT password you configured on your Victron device.
To add the Victron GX hub to your Home Assistant instance, use this My button:
Victron GX can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Victron GX.
When Home Assistant discovers your Victron GX device, it first tries to connect using TLS on port 8883. If TLS is unavailable, it tries an unencrypted connection on port 1883.
If authentication is required and your device supports MQTT token pairing, Home Assistant prompts you to enable pairing mode:
- Enable pairing mode using one of these methods:
- On the GX device, go to Settings > Integrations > MQTT Devices > Pairing mode.
- On a GX device without a built-in screen, quickly press the built-in button twice.
- In Home Assistant, select Submit within 120 seconds.
Home Assistant requests and stores the token credentials automatically. If your device does not support token pairing, enter the password configured on the GX device when prompted.
When setting up the integration manually, you need to provide connection details based on your Victron device’s security profile.
On the Victron device, go to Settings > General and check the Local Network Security Profile setting. This can be Unsecured, Weak, or Secured. If set to Weak or Secured, you must have specified a password when configuring this option.
Leave blank for unsecured and weak/secured profiles. Only use root if Venus OS is rooted with SSH access enabled.
Leave blank for unsecured profile. Enter the password you defined when setting the security profile to Weak or Secured.
Reauthentication
If your MQTT password changes or the security profile on your Victron device is updated, Home Assistant prompts you to re-authenticate:
- Go to Settings > Devices & services and find the Victron GX integration. It will show a Re-authenticate message.
- Select the Reconfigure button or the Re-authenticate prompt.
- Enter your updated Password.
- Select Submit.
On success, the integration reloads automatically.
Data updates
Entities are updated only when new values are received from the device. The integration uses an automatic update cadence chosen by metric type.
Reduce Recorder storage
The Recorder integration stores state changes in the database, so Victron GX entities can generate a lot of history data.
If you do not need every entity, go to Settings > Devices & services > Integrations, select Victron GX, select Entities, and disable the entities you do not use.
You can also reduce Recorder data growth by excluding specific high-churn Victron GX entities with Recorder filters. If you need to keep more data, set Recorder options like commit_interval and purge_keep_days in your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file to fit your setup.
For example, to exclude one Victron GX entity from Recorder:
recorder:
exclude:
entities:
- sensor.victron_venus_system_heartbeat
Supported functionality
The integration automatically discovers and creates entities for all supported Victron devices on your system. The exact entities available depend on your specific Victron hardware configuration.
Entities
The Victron GX integration provides the following types of entities:
Sensors
Read-only sensors for monitoring system metrics, such as:
- Battery voltage, current, power, temperature, and state of charge
- Solar panel voltage, current, power, and daily yield
- Grid voltage, current, power, and energy consumption
- Inverter input and output power, frequency, and state
- EV charger status, power, and session energy
Binary sensors
Status indicators for various system states, such as:
- Alarms and warnings
- Connection status
- Relay states
Numbers
Adjustable numeric settings for fine-tuning device parameters, such as:
- Battery charge current limits
- Grid setpoint for ESS
- Minimum state of charge limits
- EV charger current limits
Selects
Configurable options for controlling device behavior, such as:
- Inverter mode (on, off, charger only, inverter only)
- Solar charger mode
- Relay function configuration
- EV charger charge mode (auto, manual, or scheduled charge)
- ESS mode (optimized with or without phase compensation, or external control)
- DESS mode (auto/VRM, buy, sell, off, or Node-RED)
- ESS schedule charge slot days
Device trackers
GPS-equipped Victron devices (such as those with a built-in or connected GPS module) are exposed as device tracker entities, providing:
- Latitude and longitude
- Altitude, course, and speed (when available)
Switches
Toggle controls for enabling or disabling device functions, such as:
- EV charger start/stop
- Generator auto-start and manual start
- Generator quiet hours and conditional start triggers (SoC, temperature, voltage)
- ESS disable charge and disable feed-in
- ESS battery-only critical loads and schedule charge slot enabled
- Relay states on GX devices, Multi RS, and solar chargers
- Digital input inversion and switchable output states
- PV DC overvoltage feed-in
- VE.Bus PowerAssist, ignore AC input, and grid lost alarm settings
Times
Configurable time-of-day settings, such as:
- ESS BatteryLife schedule charge start times
Buttons
Reboot device
- Description: Reboots the GX device.
Known limitations
- The integration receives updates through MQTT push, and applies an automatic debounce interval chosen by metric type. This means rapidly changing values may appear with a short delay.
Examples
Send a notification when the battery is low
You can use this automation to receive a notification when your battery state of charge drops below a certain threshold. Replace sensor.battery_soc with your actual battery charge entity.
automation:
- alias: "Notify when battery is low"
triggers:
- trigger: numeric_state
entity_id: sensor.battery_soc
below: 20
actions:
- action: notify.notify
title: "Low battery warning"
message: >
Your Victron battery charge is at
{{ states('sensor.battery_soc') }}%.
Cannot connect
Symptom: Connection fails during setup
Description
The integration cannot establish a connection to your Victron device.
Resolution
To resolve this issue, try the following steps:
Verify your Victron device is powered on and connected to your network.
Check that the hostname or IP address is correct.
Ensure that MQTT is enabled on your Victron device.
Test connectivity from Home Assistant by opening a terminal and running:
nc -zv <VICTRON_IP> <MQTT_PORT>Replace
<VICTRON_IP>with your device’s IP address and<MQTT_PORT>with the MQTT port (usually1883or8883). If you get a timeout or error, there is a network connectivity issue. -
If Venus OS is rooted (SSH access enabled):
- Use port
8883 - Enable SSL
- Use username
root - Use the password you defined to protect the instance
- Use port
Authentication failed
Symptom: Authentication error during setup
Description
The credentials provided are incorrect.
Resolution
- Double-check the username and password if authentication is enabled.
- These are device credentials configured on the Victron device, not VRM portal credentials.
- Verify the security profile setting on your Victron device under Settings > General > Local Network Security Profile.
Token pairing failed
Symptom: Pairing fails during setup
Description
Home Assistant cannot request token credentials from the Victron GX device.
Resolution
- Enable pairing mode on the GX device.
- Submit the pairing form in Home Assistant within 120 seconds.
- If pairing mode expires, enable it again and retry the form.
No sensors appear
Symptom: Integration sets up but no entities are created
Description
The integration cannot discover or create entities from MQTT topics.
Resolution
- Verify that MQTT topics are being published by your Victron device.
- Check the Home Assistant logs under Settings > System > Logs for any error messages.
- Ensure the MQTT service on the Victron device is running and configured correctly.
- Try increasing the Elevated tracing option in the integration settings for more detailed logging.
menu. Then, select Delete.
