Vermont Castings
Support for devices by Vermont Castings in Home Assistant is provided by the IntelliFire integration.
Vermont Castings devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the IntelliFire integration.
To add the Vermont Castings integration to your Home Assistant instance, use this My button:
Vermont Castings can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
Usage information
For more documentation on how to use Vermont Castings in Home Assistant, please refer to the IntelliFire integration documentation page.
