Toshiba Lifestyle
Support for devices by Toshiba Lifestyle in Home Assistant is provided by the Midea integration.
Toshiba Lifestyle devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Midea integration.
To add the Toshiba Lifestyle integration to your Home Assistant instance, use this My button:
From the list, select Toshiba Lifestyle.
Usage information
For more documentation on how to use Toshiba Lifestyle in Home Assistant, please refer to the Midea integration documentation page.
