Sensirion BLE
Integrates sensors talking Sensirion’s BLE protocol into Home Assistant.
Adding Sensirion BLE to your Home Assistant instance can be done via the user interface, by using this My button:
In the sidebar, select Settings.
From the configuration menu, select Devices & Services.
In the bottom right, select the Add Integration button.
From the list, search and select Sensirion BLE.
The Sensirion BLE integration will automatically discover devices once the Bluetooth integration is enabled and functional.
